Warning message
2912 MFXL and GBIC Modules.
Dec 4th, 2001
Hi im using the 2912 MFXL switch with the IOS version 12.0(5.2)XU.When i install the Gbic module it gives the following error message.Can anybody help to resolve.Does it require a upgrade of IOS.
Thanks.
Module Ports Model HW Version SW version
WS-X2931-XL 1 xxxx xxxx
v.j Wed, 12/05/2001 - 01:54
Find out that the vlan in 2912 was configured on vlan 1 with ip 20.10.70.15 255.255.254.0 but the same network is configured on the MSFC for vlan 70.So after changing the config in the 2912 for vlan 70 which was not there initially, it worked fine.But still i get the Hardware and s/w version of 1000baseSX listed as XXXX,XXXX.
But it works now.
bsivasub Sat, 12/08/2001 - 10:19
I think these modules are not Hot swappable. Try powering down the whole switch and reseat the module or try in a different slot.
