Anonymous (not verified) Sat, 12/08/2001 - 07:24
Probably the best place to start is to take a look in the \documents diretory on CD #1 of your Unity install set. Under here you'll find the User Guid and Administration Guide in PDF format (there's also a PDF reader instllation if you need it). The User guide will walk you through how to sign in (use * then enter your mailbox ID when asked) and your options for addressing messages to other subscribers.
Jeff Lindborg
Unity Product Architect/Answer Monkey
Cisco Systems
[email protected]
http://www.AnswerMonkey.net (new page for Unity support tools and scripts)
