Warning message
Two ASCII terminal talking with each other through IP NETWORK
Dec 10th, 2001
Is it possible to connect two ASCII Terminal such;
Terminal+Router --(IP Network)-- Router+Terminal
Terminals are connnected via ASYNC Serial line.
And if so, how do you configure routers such that; Terminals can talk to each other through a TERMINAL EMULATION Program such as HYPERTERMINAL.
wrsteve Mon, 12/10/2001 - 05:32
We have used a serial tunnel interface in the past. It works, but if you have a line give you problems the tunnel is sensitive and will go down. The interfaces have to be reset on both ends to bring it back up. A better way is a device to convert serial to ip:
http://www.lantronix.com/products/xds/mss100/index.html
