Idle URL: Turn Off/On Trick?
We have IDLE URL working fine - it's great - HOWEVER....
We really only want to use it for annoucnements - is there a way to put a special XML instruction in the XML file durin all non-emergencies that instructs the phone that there's no file available and to check back in 60 seconds again (so that our users don't always have to be staring at a blank screen or image except when there's news (basically so the IDLE URL will actually be noticed when it's there instead of getting used to it and ignoring it...
removing the file referenced in idle url still loads up blank rather than just goin back to the line appearance display - it'd be awesome if the firmware or whatever could just be programmed to ignore the idle url if it wasn't there - any other approaches to the same problem?
- Ken
ciscomoderator Tue, 12/18/2001 - 12:41
  • Gold, 750 points or more
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
rkiamil Tue, 12/18/2001 - 16:06
You dont need to uses Idle URL, you can do a HTTP Post to the phones on your network (each phone has a web server on it, you can send information to the phone and it will be show on the screen)using ASP or ColdFusion of any application that can send HTTP Post (you could uses IE, but it would be a pain). Do you want me to send you a e.g.?
Sascha Monteiro Fri, 12/21/2001 - 08:26
  • Silver, 250 points or more
HI,
I am using the http post for a while, I can also open a rtprx/rtptx via a http post. But is there a way to post to everybody at once? I tried to broadcast but that is not working. So if you have 800 phones ( a customer of ours) than you can't do it manually.
I hope you, or someone else has a tip for me!
Sascha
