IP Phone Extension Mobility
h.vansdadia
Hi, I am configuring IP Phone Extension Mobility, I have read general documents that it requires CRM application extension.
The question I have is , do i need to install CRA on both call manager ( Priamary and Subscriber) or only on Primary.
Any help would be greately appriciated.
Himmat Vansdadia
CCIE # 4864
h.vansdadia
Hi, I gone through document but just can not figure it out what URL should i put to get login/logout services in ip phone, any help would be appriciated. I just gone through step-by-step process but not helping much.
Right pointer to configure extension mobility will be very appriciated.
thanks
Himmat
You have to point the services to the ip address of the machine that you installed the CRA software on.
Here are the two links that I used to get mobility going:-
http://www.cisco.com/univercd/cc/td/doc/product/voice/serv_fea/ext_serv/esgd03.htm
Gary
