Warning message
noc@mortgageit.com Fri, 12/21/2001 - 22:51
login in on the main page for software center
you can download a MAC CLient for VPN 3000 only
catches are its command line and for OS X only.
pforrett Mon, 04/08/2002 - 10:03
When you say "command line," do you mean that the installer is command line (which I've already done) or that using the client is from the command line (in which case I'm ready to surrender)?
seggert Fri, 03/01/2002 - 09:15
There is a client of OSx, however I am in need of a client that also works on OS9 or below.
Does anyone know of any third party solution that would work?
