Warning message
Defining VTP Domain on 2924
bsivasub Tue, 12/18/2001 - 14:13
you don't need to go into configuration mode, you need to vlan configuration mode (straight from the enabled mode)
switch#vlan database
switch(vlan)#vtp domain
You type 'exit' to save the changes and get back to enable mode.
donalwil Wed, 12/19/2001 - 11:34
Here is a link that will walk you through the set up. It should be very helpful in setting up VTP, Vlans, VMPS and Trunk Links. have a good day
Donald Williams
CCNA
http://www.cisco.com/univercd/cc/td/doc/product/lan/c2900xl/29_35wc/sc/swgvlans.htm#xtocid1196610
Beginning in privileged EXEC mode, follow these steps to configure the switch for VTP server mode:
Command Purpose
Step 1
vlan database
Enter VLAN database mode.
Step 2
vtp domain domain-name
Configure a VTP administrative-domain name.
The name can be from 1 to 32 characters.
All switches operating in VTP server or client mode under the same administrative responsibility must be configured with the same domain name.
Step 3
vtp password password-value
(Optional) Set a password for the VTP domain. The password can be from 8 to 64 characters.
If you configure a VTP password, the VTP domain does not function properly if you do not assign the same password to each switch in the domain.
Step 4
vtp server
Configure the switch for VTP server mode (the default).
Step 5
exit
Return to privileged EXEC mode.
Step 6
show vtp status
Verify the VTP configuration.
In the display, check the VTP Operating Mode and the VTP Domain Name fields.
