Warning message
Catalyst 6506
Dec 26th, 2001
First, sorry for my English.
I was updating the image of the router and I have put this in the start-configuration and now I can't enter at the router of the 6500
boot system tftp:filename
And I erased the next:
boot system bootflash:another_file
I would like to know how can I enter in rommon in the router of the 6506 in order to boot the router from the image that is in bootflash.
Can anybody help me?
bsivasub Wed, 12/26/2001 - 20:46
you need to break into the rommon while the MSFC is booting within the first few seconds.
you need to issue reset 15 or 16 and then issue "switch console" to go into the console of the MSFC and then issue the break key sequence (control break in windows2000 for hyperterminal)
