Warning message
DSP ERROR
Jan 10th, 2002
I have this error message in our AS5300.
Dec 27 20:57:39 WIB: %VTSP-3-DSP_TIMEOUT: DSP timeout on event 6: DSP ID=0x1211:
DSP error stats ***DSP VOICE ERROR STATISTICS***
Rx Pkt Drops(Invalid Header): 0, Tx Pkt Drops(HPI SAM Overflow): 0
Does it shows that one of DSP is bad?
If yes, how to know which dsp is that?
ciscomoderator Wed, 01/16/2002 - 23:17
  • Gold, 750 points or more
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
dgoodwin Tue, 02/19/2002 - 16:12
  • Cisco Employee,
Sounds like you are running into CSCdu53333 which is fixed in certain versions of IOS. If you have not already done so, please go to the Bug Toolkit on CCO to determine what version you can run, and then check the IOS/VCWare compatibility matrix to make sure you have the right VCWare version for your IOS version:
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_serv/5300/sw_conf/vcw_rn/vcwrmtrx.htm
