01-13-2002 10:09 PM - edited 03-01-2019 08:02 PM
Good Day! Can anyone tell me if it is possible, or if you have connected two router's S/T ports with a crossover cable (without using the high voltage connections)? This would be for testing/labs.
For example, connecting 2-2504s using a Cat-5 crossover cable. The cable would just be using pins 3,4,5&6 for transfer of data.
I would appreciate any information anyone could supply.
Thank you for your time.
01-15-2002 04:01 PM
No, it's not possible. Unlike a T1 back-to-back config where you can simply use HDLC keepalives to provide your layer 2 connectivity, ISDN requires signalling from the switch to establish that the circuit is indeed up. There's a lot more to it than just voltage and circuits being complete, as DEBUG ISDN Q921 and DEBUG ISDN Q931 will show.
01-15-2002 07:29 PM
Thank you for your time and info. Barry
01-20-2002 09:59 PM
Rollin:
Hello! Thank you for responding to my question. You mentioned a T1 back-to-back configuration. I am still researching this, but if you don't mind helping once more, can I use a crossover cable between 2 NT1 units? Conversely, could you point me in a direction for more info?
Thank you again for your time.
Best Regards,
Barry Mason, CCNA
01-15-2002 04:15 PM
No this is not possible on the 2500 series. We do have some products that support network side bri but I am not sure if you can make calls from one to another if they are directly connected.
Josh
01-15-2002 07:30 PM
Thank you for your time and info. Barry.
