Warning message
Catalyst 2924 issues
Jan 15th, 2002
I have a Catalyst 2900 series (model WS-C2924C-XL) switch that I wanted to update the software on. I downloaded c2900XL-c3h2s-mz.120-5.WC2.tar, which is evidently the WRONG software to put on this model switch, and after I loaded it and rebooted the switch, I could no longer manage the switch via Web Browser, but I could still Telnet to it. I had backed up the previous software but inadvertantly deleted it in the process.
So my only alternative that I saw was to load the ORIGINAL 4Mb software for the switch (c2900XL-hs-mz-112.8.6-SA6.tar). After I got that successfully loaded, I had to re-configure the switch, and it never prompted me for a Telnet password, only a "secret" Administrative password. I can now manage it via the web browser again, but now I can't telnet to the switch. When I try to Telnet, i get "Password required, but None Set".
So my questions are:
1. What is the latest version of software for this switch and/or how do I find the previous version that was on here before I messed it up? (It's not listed on site!)
2. How do you recover a TELNET password? Does it have something to do with the version of software that I installed on the switch?
jevansau99 Wed, 01/16/2002 - 01:51
just do this from the console port:
prompt>en
prompt# conf t
prompt# line vty 0 4
prompt# password "yourpass"
that will set your telnet pass. it is recommended that you use your command line to config switches and turn off the web admin for cisco devices.
