jbohla Mon, 01/21/2002 - 13:00
We use the Cisco 340 and 350 PCMCIA nics but I understand most 802.11b compliant cards work. Are you using the bridge as an access point?
xdavila Fri, 02/01/2002 - 09:43
I used a regulat E-Link card and it worked.
Did not like the way D-Link set up is but worked.
shaun.oliver Sun, 02/03/2002 - 18:59
The Aironet 340 or 350 PCMCIA cards both work fine, but the 350 would be preferred - it's got better power output, and seems to have better receiver sensitivity.
blue.modal Thu, 02/07/2002 - 08:22
The Cisco 350s cards do have a power advantage, but any card can be made more effective with an external antenna - the trick is getting one to integrate with the end-user device.
If you are having trouble with distance or multi-pathing at the client down inside the guts of your plants, I would suggest an AIR-LMC352 with two stick-on antennas attached to the back of the monitor (assuming it's a portable).
You may get 4x performance for an extra $200-300.
OR, you can set everything to 1Mbps only and tolerate much more interference.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
