Warning message
Disabling inbound Caller ID on CCM3.1(2c)
Jan 16th, 2002
Does anyone know if it is possible to disable inbound caller ID on Call Manager 3.1(2c) with a 6608 gateway using a PRI? If so, how? The presentation bit takes care of the outbound, but my client wants to block inbound CLID as well.
ciscomoderator Fri, 01/25/2002 - 13:40
  • Gold, 750 points or more
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
