Warning message
ipsec isakmp access-lists for traffic to encrypt and security?
Jan 17th, 2002
I am working on setting up a vpn connection point-to-point.
the encryption is working.
crypto isakmp policy 100
hash md5
authentication pre-share
crypto isakmp key gemplus address 10.3.162.2
crypto ipsec transform-set g_tran ah-sha-hmac esp-3des
crypto map g_map 10 ipsec-isakmp
set peer 10.3.162.2
set transform-set g_tran
match address 151
interface Serial0/0:0
ip address 10.3.162.1 255.255.255.252
ip access-group 120 in
no cdp enable
crypto map g_map
ip route 192.11.61.105 255.255.255.255 10.3.162.2
The access-lists I have defined are:
access-list 120 permit ahp any any
access-list 120 permit esp any any
access-list 120 permit udp any eq isakmp any eq isakmp
access-list 151 permit ip host 10.30.49.5 host 192.11.61.105
the config is the same in reverse at the other router end.
when I ping from 10.30.49.5 to 192.11.61.105 I get no reply. I have defined the encryption access to the interface and the crypto map to the access-list to define what is being encrypted.
I can only get it working when I define on the interface non encrypted ip traffic between 10.30.49.5 and 192.11.61.105.
Note: Config modified for security resons so please ignore spelling mistakes.
thanks in advance.
bseddik Tue, 01/22/2002 - 14:35
Especially with Ipsec, (it seems that) the acl 120 is applied twice on the s0/0:0
- first, it is applied to the inbound uncrypted
traffic
- second, it is applied again after decrypting.
The solution is to complete the acl 120 for the permitted encrypted traffic.
bye
