Warning message
Help needed with 806 NAT setup.
Jan 21st, 2002
Ok, first off, I know hardly anything about this but got stuck doing it anyway.
I'm attempting to setup a cisco 806 with NAT. It will be connected between a DSL router and the LAN to provide internet access to stations on the LAN. I have to do the routing and NAT here because the DSL router won't do it, and the way the ISP assigns the IP's is a little screwy.
I need it to do nat from the inside addresses 10.0.0.x to the outside public addresses 65.x.x.x.
I'm using the standard IOS software, do I need a different feature pack?
From the 806:
I can ping DSL router
No name resolution out.
I can ping LAN
From local station:
I can ping Lan int on 806
all other outside pings return dest unreachable
DSL Router:
LAN int set on 65 net
NAT off
DHCP off
If I switch the local machine over to the 65 net (IP and GW) it works fine. But the local machines MUST remain on the 10.0.0.x net.
Am I going about this all wrong?
Here's what I have so far. Thanks for any help you can give. Here's an example of what I'm trying to do.
http://www.precdata.com/network.jpg
Is this even possible to do?
show run
Building configuration...
Current configuration : 1480 bytes
version 12.2
no parser cache
no service single-slot-reload-enable
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname xxxx
logging rate-limit console 10 except errors
enable secret 5
enable password 7
username xx password 7
ip subnet-zero
ip name-server 205.152.0.x *********ISP DNS servers
no ip dhcp-client network-discovery
lcp max-session-starts 0
interface Ethernet0
description LAN connection ********Connected to LAN hub
ip address 190.20.50.111 255.255.255.0 *********Set as gateway on local
machines
ip nat inside
no cdp enable
hold-queue 32 in
interface Ethernet1
description WAN connection to ISP
ip address 65.x.x.2 255.255.255.0 ******** (one of 5 public IP's, other
2 will be static later connected to DSL router)
ip nat outside
no cdp enable
router rip
version 2
network 190.20.0.0
no auto-summary
ip default-gateway 65.x.x.1 **********(dsl router lan
interface)
ip nat pool DynamicUsers 65.x.x.4 65.x.x.5 netmask 255.255.255.0
*********2 of the 5 public IPs that private dhcp stations will use for
internet.
ip nat inside source list 1 pool DynamicUsers overload
ip classless
ip http server
access-list 1 permit 190.20.0.0 0.0.255.255 **********(allow everything
from this net to go out)
access-list 111 permit icmp any any echo
access-list 111 permit icmp any any time-exceeded
access-list 111 permit icmp any any echo-reply
line con 0
exec-timeout 120 0
stopbits 1
line vty 0 4
exec-timeout 0 0
login local
length 0
scheduler max-task-time 5000
end
kowhai Mon, 01/21/2002 - 08:49
What DSL Router are you using?
-Peter
