Warning message
How can I transfer voice through the network?
Jan 28th, 2002
I have bought a gateways EWG-904S product of ANTek,it support H.323 voice and connect to interent..
Structure of NETWork for Macau office(Local) : ADSL modem -> Router(Normal) -> HUB -> Another Router -> EWG-904S [I have insert the phone set(can hear the dial tone when I hook the telephone),WAN Port use RJ45 link the HUB to another side,RS232 port insert to PC serial port(for config)]
** Remote site for Hong Kong : Have EWG-904(server mode) already [It's code is X01# (mean it's IP address)] and can ping it sucessful.
Result of Problem : I can ping -> another Router & EWG-904S and direct to INTERNET,press X01# can get the Dial tone to Hong Kong immediately.
Test : If I don't use the current Router and use ADSL Modem -> EWG-904S directly,I can direct to use INTERNET and press X01# to get the dial tone(mean that it can ping the IP address of Hong Kong immediate).
%%% Do I need to find another Router that it can support H.323 Voice function,compatible EWG-904S to get the dial tone?
Any product(please send me detail and price,if u can) can introduce for me?Any solution suggest to me???
Please give me the answer asp!!!Urgent....thx..
