Limiting Bandwidth
Jan 28th, 2002
I have a Cisco 2620 router (connected to a T1). I want to be able to limit the bandwidth useage based on an IP address of a user inside my network. I researched CAR (committed access rate) but found out that it only works with the 7xxx series. Any suggestions?
beth-martin Mon, 02/04/2002 - 07:34
  • Bronze, 100 points or more
CAR is an IOS feature available from Cisco for your 2600. I ran it on feature navigator (www.cisco.com/go/fn) and it shows support since 12.0.(1)T. You’ll need to contact your Cisco rep for a software upgrade.
ramesh.krishnan Mon, 02/11/2002 - 10:11
hi,
for limiting a user's bandwidth you can use the rate-limit comand.
For limiting by IP..u create a extended access-list say 110
then to your gateway interface you can put rate limit
like
rate-limit input access-group 110 60000 10000 10000 conform-action transmit exceed-action drop
The above ids to limit his input..now substitute ipput with output to limit his output.
Ramesh
