MOH
Jan 29th, 2002
After configuring MOH server running on CCM 3.1(2c)
i can see neither "IP voice media streaming-app" started at control serviceability center nor MOH service running on WIN 2000.
MOH is not working.
paul.harrison Tue, 01/29/2002 - 06:10
  • Bronze, 100 points or more
A few things to look at
Have you configured the media resource group
Have you added the MOH server to the resource group
have you assigned the MRG to the device pool
are the gateways in the device pool
have you adjusted the volume on the handset (MOH tends to be quiet)
have you reset the devices in the device pool.
Paul
MARTIN IVAN Tue, 01/29/2002 - 12:14
I have had everything configured in a way you told BUT the "Cisco IP Voice Media Streamer" Optional Component WHICH I HAVE NOT.
Tommorow i add this component,then i let you know.
Martin
MARTIN IVAN Wed, 01/30/2002 - 13:13
Paul,
I added Optional component and it really works!!
Martin
