user-maxlinks 1
Feb 1st, 2002
I have defined this:
user test1 user-maxlinks 1 passowrd 0 test2
If I've understood the user-maxlinks function , when user test1 makes an ISDN call he only can get 1 channel B , but in my case he gets 2 channels.Why ?
jduffek Mon, 02/04/2002 - 22:23
Sounds like a bug, then again maybe you have to turn on local aaa authorization for that to work, what do I know. What version are you running and what does your config look like?
Josh
maller Tue, 02/05/2002 - 07:19
I'm working with c3640-is-mz.122-4.T.bin. This is my AAA config :
aaa authentication ppp default local
aaa authorization network default local
I work with dialer profiles
mazhar71 Thu, 02/07/2002 - 00:15
I think this is a bug. Cisco site says "In multilink environments, each PPP multilink connection is counted as one connection".
maller Thu, 02/07/2002 - 03:07
You are alright, with IOS ver c3640-is-mz.122-4.T.bin
user-maxlinks command doesn't run.
With c3640-is-mz.122-7.bin, it runs fine.
