Warning message
2 Vlans Talking to each other
I am rookie when it comes to vlans so please keep this in mind.
What I am trying to accomplish is we have a 10.16.0.0/16 network.
I want to create 2 vlans (to seperate traffic)
like have 10.16.1.1-20 on 1 vlan and 10.16.1.21-40 on another, can I do this and have them talk to each other and accomplish seperate broadcast domains with the vlan?
Thanks again
r-godden Wed, 02/06/2002 - 01:42
if you use vlans then you will need to route between
them.
for 20 hosts per vlan use 27 bit mask 255.255.255.224 this will divide your addresses into
0-31 32-63 etc
ejgonzalesiii Wed, 02/06/2002 - 08:45
Yes this will work only if the router that you are using supports trunking.
-Henry
paquino Fri, 02/08/2002 - 14:25
Ok
1. It seems like the 10.16.1.1-20 and the 10.16.1.21-40 fall within the same 255.255.0.0 IP subnet. In this case saparating these ip addresses with a vlan would totally isolate isolate the machines from one another.
vlan 1 10 .16 .1. 1-20
vlan 2 10 .16 .1. 21-40
255.255.0. 0
these are the same ip subnet.
2. If you meant the subnet 10.16.0.1-20 and
10.17.0.1-20 then they would be seperate broadcast domains but unable to talk to one another without a layer 3 interface for routing. So the answer is no you still wouldnt have full connectivity.
Lemme know if this helps
Sincerely,
Paul Aquino
CSE
Cisco Systems
ryan.vaughn Mon, 02/11/2002 - 07:57
I have done something similar to this, but not exactly what you are looking at.
I use Bay Networks Baystack 350T switches to seperate my vlans behind the router. Normally, I only vlan seperate subnets, but it should also work for vlans inside a subnet. We use this to run a single line into a building and seperate the tenant traffic via vlans to a single interface on a cisco router. I have never gotten a cisco catalyst switch to do the same thing I have seen with Baystack switches. I am not sure if this is because of functionality or inexperience on my part with catalyst switches (probably the latter of the two.)
I would NOT recommend taking this path however. If you want to seperate the 2 networks, I would recommend routing the two segments of the network between two interfaces on a router in two seperate networks. I just believe in presenting all options ;c)
