Telnet - Can't Access
tepatel Mon, 02/11/2002 - 19:52
  • Cisco Employee,
If you can't access (telnet) the router from outside then we might have to check the "sh run".
By the way i can ping 63.243.20.218 but can't telnet from my pc on the internet so looks like the telnet access is denied by access-lists or some other way.Let us have sh run from the router .Thx..Tejal
DOES THIS TELL YOU ANYTHING? I took out the passwords...
service timestamps debug uptime
service timestamps log uptime
service password-encryption
no service tcp-small-servers
no service udp-small-servers
hostname ALARouter
enable secret
no ip name-server
ip subnet-zero
no ip domain-lookup
ip routing
interface Ethernet 0
no shutdown
description connected to EthernetLAN
ip nat inside
keepalive 10
interface Ethernet 1
no description
no ip address
ip nat inside
shutdown
interface Serial 0
no shutdown
no description
no ip address
encapsulation frame-relay
frame-relay lmi-type ansi
interface Serial 0.1 point-to-point
no shutdown
description connected to Internet
ip address 63.243.20.218 255.255.255.252
ip nat outside
frame-relay interface-dlci 103 ietf
! Access Control List 1
no access-list 1
access-list 1 permit 192.168.1.0 0.0.0.255
! Dynamic NAT
ip nat translation timeout 86400
ip nat translation tcp-timeout 86400
ip nat translation udp-timeout 300
ip nat translation dns-timeout 60
ip nat translation finrst-timeout 60
ip nat inside source list 1 interface Serial 0.1 overload
! DHCP Server
service dhcp
ip dhcp excluded-address 192.168.1.1 192.168.1.5
ip dhcp pool 1
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 205.218.123.50 66.43.137.27
router rip
version 2
network 192.168.1.0
passive-interface Serial 0.1
no auto-summary
ip classless
! IP Static Routes
ip route 0.0.0.0 0.0.0.0 Serial 0.1
no ip http server
snmp-server location Birmingham Office
snmp-server contact Jay Tatum,205.402.0081,[email protected]
banner motd # American Lung Association
When You Can't Breathe, Nothing Else Matters
www.americanlung.org
line console 0
exec-timeout 0 0
password
login
line vty 0 4
password
login
end
tepatel Tue, 02/12/2002 - 09:10
  • Cisco Employee,
The config looks OK..Its not configured to block any traffic. So you might want to check the router/devices before this router for any of such blocking..Thx..Tejal
tepatel Tue, 02/12/2002 - 09:16
  • Cisco Employee,
Just to add to that, you can check that the tcp packets are even reaching to the router or not while you try to attempt the telnet connection to it. Use
debug ip tcp packet in address 63.243.20.218 port 23
to track the tcp packet for telnet for address 63.243.20.218...Thx..Tejal
robstarke Wed, 02/13/2002 - 08:57
Jay,
I'm not going to be much help here, but I wanted to put my two cents in anyways. I have had this problem within my lab. It did come down to a NAT issue, and I found that out my looking at the debug output (debug ip nat det).
My fix was to static NAT the router IP Address and telnet to the NATed IP.
Let me know if this helps,
Rob Starke
tepatel Wed, 02/13/2002 - 09:07
  • Cisco Employee,
As i mentioned, lets enable the debug
on the router to track the tcp packet for telnet for address 63.243.20.218 is even hitting the rotuer or not.If the packets are not reaching, then we know that its blocked somewhere in the middle....Thx..Tejal
zahmed Wed, 02/13/2002 - 13:18
  • Cisco Employee,
Actually if you do not have vty password set, it gives you the message "password required, but none
set".
If you are not seeing this message, then its not
the password issue. I wonder if telnetting from the
router enable prompt to its WAN address is successful?
