Warning message
3.1.3a ip phone firmware
Feb 13th, 2002
Hi, in release notes of 3.1.3.a it says that this version has been tested with P00303010108 firmware for IP Phone 7960/7940. After the CM upgrade, the firmware of the IP Phones is P00303010107.Does anyone know where can I find which is the correct one?
We are having some -minor,lets say- problems after the upgrade. The dial-speed buttons do not work properly. They work for internal numbers only, not for PSTN....We have noticed also that in one expansion module, the configuration of the buttons was changed and the user has to change them back as he had configured them....
I would appriciate any help
Yanna
vimoreno Wed, 02/13/2002 - 10:08
  • Cisco Employee,
The default installation will include P00303010107. Stay tuned for the release of the P00303010108 firmware on CCO. The service pack should also include a list of the caveats addressed by it, the main one being SRST enabling issues.
i.fouraki Thu, 02/14/2002 - 23:32
thank you for yor response. Is there a problem with SRST with the current firmware?
We use SRST in all Branch IP Phones....
Yanna
