Warning message
Disabling Display Screen Info on 7910
Feb 14th, 2002
Hello People,
Is it possible to totally disable the display on 7910's. Or better still just disable certain aspects. For instance if a user using an internal set(internal calls allowed only) dials another phone which is call forwarded to lets say a mobile number, the caller from the internal phone now sees that mobile number.
Basically I'm trying to curb users from inadvertently getting mobile or other numbers in this fashion.
Any help appreciated
Scuzzie
rkiamil Thu, 02/14/2002 - 10:14
You could make the other user forward there calls to an Hoy Key number e.g. 6000 > 07973222555. That way there user will not see the moblie number and only the Hot Key
Rif
dakeller Tue, 02/19/2002 - 08:47
  • Cisco Employee,
Unfortunately, there is no way to programmatically disable the display on any of the 79xx phones.
Dan Keller
Cisco Systems
