IDSN router calls another without any reason
Feb 18th, 2002
Hi, I have scenario of 2 remote ofices, Cico 1601 router in each. Router in first office calls second office and establishes TCP/IP connection. The problem is that first ISDN router makes a call to other router without any reason aprox 10 min. After 2 min (iddle timeout) ir drops this call. That involves unnecessary international call costs. using IOS verion 12.2.6c. Configuration of first router is following:
service timestamps debug uptime
service timestamps log uptime
service password-encryption
no service tcp-small-servers
no service udp-small-servers
hostname Cisco1601_Vilnius
enable password dddddddd
username Cisco1601_Riga password chappassw
ip source-route
no ip name-server
isdn switch-type basic-net3
ip subnet-zero
no ip domain-lookup
ip routing
interface Dialer 1
description connected to Cisco1601_Riga
ip address 192.168.109.1 255.255.255.252
ip access-group 101 in
no ip split-horizon
encapsulation ppp
dialer in-band
dialer idle-timeout 120
dialer hold-queue 10
dialer map snapshot 1 name Cisco1601_Riga 08103717505231
dialer map ip 192.168.109.2 name Cisco1601_Riga speed 64 08103717505231
dialer-group 1
ppp authentication chap
no ppp multilink
snapshot client 15 360 suppress-statechange-update dialer
no cdp enable
interface Ethernet 0
no shutdown
description connected to EthernetLAN
ip address 192.168.0.252 255.255.255.0
ip access-group 100 in
keepalive 10
interface BRI 0
no shutdown
no ip address
dialer rotary-group 1
interface Serial 0
no description
no ip address
shutdown
! Access Control List 100
! For outgoing trafic allow TS (Terminal server) from client to server and ping
no access-list 100
access-list 100 permit tcp host 192.168.0.40 gt 1100 host 192.168.2.2 eq 3389
access-list 100 permit tcp 192.168.0.0 0.0.0.255 host 192.168.0.252 eq telnet
access-list 100 permit udp 192.168.0.0 0.0.0.255 host 192.168.0.252 eq tftp
access-list 100 permit icmp host 192.168.0.40 host 192.168.2.2 unreachable
access-list 100 permit icmp host 192.168.0.40 host 192.168.2.2 echo-reply
access-list 100 permit icmp host 192.168.0.40 host 192.168.2.2 packet-too-big
access-list 100 permit icmp host 192.168.0.40 host 192.168.2.2 time-exceeded
access-list 100 permit icmp host 192.168.0.40 host 192.168.2.2 traceroute
access-list 100 permit icmp host 192.168.0.40 host 192.168.2.2 administratively-prohibited
access-list 100 deny ip 192.168.109.0 0.0.0.3 any
!!access-list 100 deny ip 192.168.2.0 0.0.0.255 any
!!access-list 100 permit tcp any any established
!!access-list 100 permit tcp any 192.168.109.0 0.0.0.3 range 20 21
!!access-list 100 permit tcp any 192.168.2.0 0.0.0.255 range 20 21
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 deny ip any any
! Access Control List 101
! For incomming trafic allow TS from server to client and ping
no access-list 101
!!access-list 101 deny ip 192.168.0.0 0.0.0.255 any
!!access-list 101 permit tcp any any established
access-list 101 permit tcp host 192.168.2.2 eq 3389 host 192.168.0.40 gt 1100
access-list 101 permit icmp host 192.168.2.2 host 192.168.0.40 unreachable
access-list 101 permit icmp host 192.168.2.2 host 192.168.0.40 echo-reply
access-list 101 permit icmp host 192.168.2.2 host 192.168.0.40 packet-too-big
access-list 101 permit icmp host 192.168.2.2 host 192.168.0.40 time-exceeded
access-list 101 permit icmp host 192.168.2.2 host 192.168.0.40 traceroute
access-list 101 permit icmp host 192.168.2.2 host 192.168.0.40 administratively-prohibited
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 deny ip any any
! Dialer Control List 1
no dialer-list 1
dialer-list 1 protocol ip permit
ip classless
! IP Static Routes
ip route 192.168.2.2 255.255.255.255 192.168.109.2
ip route 0.0.0.0 0.0.0.0 192.168.0.15
no ip http server
no snmp-server
line console 0
exec-timeout 0 0
password zz
login
line vty 0 4
password zz
login
end
Could anybody tell how to make C1600 not to call if isn't necessary ?
Mindaugas Saulis
Systems Expert,Adventus Solution
[email protected]
tel: +370-2660088
tepatel Mon, 02/18/2002 - 09:47
  • Cisco Employee,
"debug isdn q931" along with "debug dialer" will tell us everyting about "why" the isdn line dialout.
But looking from the config, since all the ip traffic is interisting, i think that may be bringing the line up.
So lets turn on the debug for a call.
debug isdn q931
debug dialer
Thx..Tejal
zahmed Mon, 02/18/2002 - 23:21
  • Cisco Employee,
Right now, you have :
dialer-list 1 prot ip permit
Make it : dialer-list 1 prot ip list 101
and create access list 101 :
acc 101 deny ip any host 255.255.255.255
acc 101 perm ip a a
If this doesnt stop it, capture debug dialer and
debug dialer packet.
Kevin Dorrell Wed, 02/20/2002 - 14:45
  • Green, 3000 points or more
While it is connected, do "show dialer int Dialer1". That will tell you at least the source and destination IP addresses of the packet that opened the link.
Following on from that, the control over the link really resides in the dialer-list.
You could also try putting an outgoing access list on the dialer interface, permitting everything that might be interesting , but with the keyword "log".
