Warning message
Unable to ping other side of 802.1q trunk links on 3500XL
Hopefully you can point out my mistakes here.
I can ping the Extreme, but can't ping the 3500XL nor either server. All connections are 802.1q trunk links. The native VLANs for Server23 and Server24 are 23 and 24, respectfully. Sorry for all the x's...the posting system here is messing with my diagram..
xoxoxoxoxoxoxoxoxoxoExtreme Switch
xoxoxoxoxoxoxoxoxoxo10.6.200.2
xoxoxoxoxoxoxoxoxoxo|
Router A--------- 3500XL------ Server23
xoxoxoxoxoxoxoxoxo 10.6.200.3 10.6.23.2
xoxoxoxoxoxoxoxoxox|
xoxoxoxoxoxoxoxo Server24
xoxoxoxoxoxoxoxox 10.6.24.2
*Server gateways point to their respect subif on the router (i.e. 10.6.24.2 is using 10.6.24.1 on Router A)
** Both the Extreme and the 3500XL are using 10.6.200.1 as their default gw.
Subifs on router A:
subif .1 10.6.200.1
subif .23 10.6.23.1
subif .24 10.6.24.1
!Relevant 3500XL config
interface FastEthernet0/1
switchport trunk native vlan 1
switchport mode trunk
interface FastEthernet0/2
switchport trunk native vlan 23
interface FastEthernet0/3
switchport trunk native vlan 24
interface FastEthernet0/4
interface VLAN1
ip address 10.6.200.3 255.255.255.0
no ip directed-broadcast
no ip route-cache
ip default-gateway 10.6.200.1
bsivasub Wed, 02/20/2002 - 17:37
few questions
1) why are you trunking to the servers ? if it is just a single vlan (23 or 24), why not make it access port.
2) can you provide us with the config on the router ?
I am assuming you are trying to ping from the router to the servers, do you see arp entries getting populated ?
1.) We develop a special network measurement device that can use a 802.1q trunk connection. As part of the testing, we needed the link to be a trunk, not a access link. 2) I just found the problem - a subif (.23) was shutdown for some reason. After issueing a no shut, everything was fine and well. D'OH!
