Cisco ACS 3.0NT - Win2K Applic Log Error messages
Feb 21st, 2002
Is anyone else getting the following error messages in the application log of Win2k with Cisco ACS 3.0 :
Here is the info, Errors are seen in the Application Log with "Perflib" being the source:
Error 1:
ciscoacs: The data buffer created for the CSTacacs service in the C:WINNTsystem32tac_mon.dll library is not aligned on an 8-byte boundary. This may cause problems for applications that are trying to read the performance data buffer. Contact the manufacturer (msg #1)
Error 2:
ciscoacs: The data buffer created for the CSRadius service in the C:WINNTsystem32rad_mon.dll library is not aligned on an 8-byte boundary. This may cause problems for applications that are trying to read the performance data buffer. Contact the manufacturer (msg #1)
Also getting this one:
Error 3:
CSMON Message: Authentication server down. Could not change Password.
Running Cisco ACS 3.0(1) Build 40, on Win2K Server SP 2
cjacinto Thu, 02/21/2002 - 16:13
  • Cisco Employee,
Error 1 and 2 are benign errors and is known by the ACS dev team. It is about erroneous monitoring on W2K. Error 3, seems the Authentication services was
down when the change of password was attempted. It could have been attempted the same time replication was happening in the background or a backup process is in place both of which causes the authentication services to shut for the time being.
