Warning message
IDS and CSPM 2.3i
Feb 23rd, 2002
I am trying to configure the IDS 4210 with CSPM 2.3i. I try to add the sensor using the wizard and choose the "verify IP address". The CSPM says that it is unable to communicate with the sensor. I checked my sysconfig-sensor settings and am able ping the CSPM host server from the sensor and vice-versa. Any ideas?
bhose Tue, 02/26/2002 - 21:05
Make sure all you POP protocol settings are correct between the sensor and CSPM.
Sensor host ID, Sensor organization ID, IDS Manager host ID,Manager organization ID etc
