Warning message
Error message on Updating Sensor with IDSk9-sp-3.0-5-S17.bin
Feb 25th, 2002
Sucessfully Updated sensor with IDSk9-sp-3.0-4-S16.bin. Could not updated sensor with IDSk9-sp-3.0-5-S17.bin. Both files were downloaded in the same manner and transfered to the sensor.
Here is the following error message:
# ./IDSk9-sp-3.0-5-S17.bin -I
Invalid character (0x0) on line 39935
No end line
tar: read error: unexpected EOF
chmod: WARNING: can't access ./SEN305SP/install/ids-patchinstall
Files were downloaded from Cisco's http download site. Downloaded the S17 release twice same error occurs. Is there a problem with the file?
rwassom Mon, 02/25/2002 - 12:07
Verify checksums for the file you downloaded match the values listed on the software download page to make sure the file was tranferred successfully.
pgomes Mon, 02/25/2002 - 12:51
Thank you, for the confirmation that the file worked for someone. I re-downloaded the file and ensured the checksums matched. It executed as expected.
