02-25-2002 11:45 PM - edited 03-12-2019 02:34 PM
Hi all,
I have Problems with extension Mobility feature on CallManager 3.2.
I have installed the CRA like described. I have the login reguest on the IP Phones. But when i try to login the "Please Sign On" Message appears on the Display.
Any Experiences ?
mehmet
02-26-2002 12:02 AM
Hi Mehmet,
Did you read the releasenotes? CRA is not working (yet) on cm3.2!.
Extended Services should work though, but I have the same problem with ES 2.2(3a) It did work with ES 2.2(2)!
Sascha
02-26-2002 12:15 AM
Hi Sascha,
ok..I was not careful:))
I must wait until the patches for JTAPI and DC Directory become available.
Mehmet
02-26-2002 02:05 AM
Hi, I've the same problem, in the release notes is descrbed that the test with ES version 2.2(3a) it's OK, I've installed this version but it not seems to be working.
02-26-2002 01:39 PM
I had the same problem. I deinstalled ES 2.2(3a)and installed ES 2.2.2 After this EM was working again. There is a TAC case for this problem and the latest info is that this problem is solved in the first service release of CM3.2
