Warning message
BGP redistribution
Feb 26th, 2002
Could someone confirm or deny my theory that it is impossible to redistribute BGP into any other routing protocol via simple redistribution.
I have tested this in the lab, the syntax is there but the redistribution does not work. It makes sence that I can not redistribute (roughly 65,000 routes into the LAN environment), yet perhaps it could be done if I used some sort of route filtering?
Ex:
router EIGRP 100
redistribute BGP 64512 metric 1000 100 255 1 1500
ruwhite Wed, 02/27/2002 - 04:39
  • Gold, 750 points or more
Nope--it's not true. You can redistribute eBGP routes into any other protocol (though I would question why you'd want to). iBGP can be done too, but it's not as easy, it's not (generally) safe, and it's _not_ recommended in any way shape or form.
Redistributing eBGP into an IGP with heavy filtering isn't unheard of, but a single mistake letting all the internet routing table into the igp, 150,000+ routes, would be a real network killer.
Russ
