Warning message
Setting for Cisco 4000
Feb 28th, 2002
Does anyone has experience in configuring cisco 4000 switch as Layer 2 connected with 3rd party switch using GigaEthernet uplink?
Any advice is greatly appreciated ?
Prashanth Krishnappa Thu, 02/28/2002 - 17:59
  • Cisco Employee,
You should be able to connect the CAT400x switch to any third party switch just as a regular VLAN port or a dot1q trunk(if you have multiple vlans). If you have already tried it, are you seeing any issues?
n.tan Thu, 02/28/2002 - 18:50
I have tried to conenct the Cisco 4006 switch and has a lot of FCS error and RX error on the GigaEthernet. What are the setting need to disabled for Cisco 4006 ?
Please advise.
n.tan Fri, 03/01/2002 - 06:45
Thank for your reply.
I have changed the fibre cable. To isolate the problem, I have changed interconenction to UTP. There is no FCS and RX error but I have issue on ARP.
Currently, I have problem in ping from L3 switch to Cisco 4006 on the GigEthernet cisco 7206 router.At the PC end, I can ping the cisco router 7206
From L3 switch, I can see the ARP entry for the cisco router.
Any setting needed to enabled on the mac aging timer ?
Please advise. The L3 TTL switch is set at 360min ?
Thanks & Best Regard
