Warning message
VPN problems with Windows 2000
We are having some problems with windows 2000 and vpn. For some of our users windows "hangs" when applying the personal settings and takes some users 30 minutes to log into our domain. We have VPN set to start before log on so that they can map their drives.
This problem seems associated with specific routers in that the Linksys router is the worse. I was wondering whether anyone has experienced similar issues on Windows 2000 and VPN and inordinate amount of time to get authenticated to a domain.
Any help would be appreciated. Thanks
You can also email me at [email protected]
j.velasquez Fri, 03/01/2002 - 14:43
Have you set the MTU size to 1400?
Does your router have a helper-ip address set for the VPN subnet?
