Warning message
Subnet Mask Selection for ATM Backbone
Mar 3rd, 2002
Is there a disadvantage of assigning a 30 bit mask to an ATM interface which is part of a ATM backbone using Multipoint? With a hub and spoke design serial links are commonly assigned 30 bit masks to conserve IP addesses and reduce routing table. Is true in designing an ATM backbone too?
bsivasub Sun, 03/03/2002 - 19:47
why not !!! It should be fine... Not aware of any atm specific issues... just treat that like any other wan connection.
svermill Mon, 03/04/2002 - 08:02
I would base the mask on the number of end points on that multipoint. A /30 mask allows for only two. You may very well need more I would think.
