Warning message
Little Question about ISDN
Mar 7th, 2002
Anybody know, i may using Qsig protocol for organizing Dial-Up access to 3620 router? What need version IOS may using for this?
No found answer in documentation on CCO.
tdn2 Fri, 03/08/2002 - 05:37
This document help about using Qsig for VoiceIP application, no about Dial-Up. This function supported?
I configure this. No work.
See deb isdn q931
1d02h: ISDN Se1/1:15: RX <- SETUP pd = 8 callref = 0x1102
1d02h: Bearer Capability i = 0x8090A3
1d02h: Channel ID i = 0xA98381
1d02h: Progress Ind i = 0xA590 - Reserved value
1d02h: Progress Ind i = 0x8581 - Call not end-to-end ISDN, may have in-b
and info
1d02h: Called Party Number i = 0xC9, '279', Plan:Private, Type:Subscribe
r(local)
1d02h: Sending Complete
1d02h: Locking Shift to Codeset 5
1d02h: Codeset 5 IE 0x31 i = 0x81
1d02h: Codeset 5 IE 0x32 i = 0x80
1d02h: ISDN Se1/1:15: Incoming call id = 0x021E, dsl 0
1d02h: ISDN Se1/1:15: NegotiateBchan: bchan 1 intid 0 serv_st 0 chan_st
0callid
0x0000 ev 0x90 n/w? 0
1d02h: Negotiated int_id 0 bchan 0 cr=0x9102 callid=0x021E lo_chan 1 final
int_i
d/bchan 0/1 cause 0x0
1d02h: ISDN Se1/1:15: LIF_EVENT: ces/callid 1/0x21E CALL_INCOMING
1d02h: ISDN Se1/1:15: CALL_INCOMING dsl 0 bchan 0
1d02h: ISDN Se1/1:15: CALL_INCOMING: call type is VOICE ALAW, bchan = 0
1d02h: ISDN Se1/1:15: Event: Checking if call is not ISDN end to end
1d02h: ISDN Se1/1:15: Event: Received a VOICE call from on B0 at
64 K
b/s
1d02h: ISDN Se1/1:15: RM returned call_type 1 resource type 0 response 1
1d02h: ISDN Se1/1:15: VOICE_ANS Event: call id 0x21E, bchan 0, ces 1
1d02h: ISDN Se1/1:15: isdn_send_connect(): msg 74, call id 0x21E, ces 0
bchan 0,
call type VOICE
and info
r(local)
1d02h: ISDN Se1/1:15: RX <- RELEASE_COMP pd = 8 callref = 0x1102
1d02h: Cause i = 0x80E6 - Recovery on timer expiry
1d02h: ISDN Se1/1:15: CCPRI_ReleaseCall(): bchan 1, call id 0x21E, call type
VOICE
1d02h: CCPRI_ReleaseChan released b_dsl 0 B_Chan 1
1d02h: ISDN Se1/1:15: LIF_EVENT: ces/callid 1/0x21E CALL_DISC
1d02h: ISDN Se1/1:15: LIF_EVENT: ces/callid 1/0x21E CALL_CLEARED
1d02h: ISDN Se1/1:15: received CALL_CLEARED call_id 0x21E
Software ROM: 3600 Software (C3620-DO3S-M), Version 12.2(2)T, RELEASE SOFTWARE (fc1)
In than problem?
Thank you.
mljohnson Mon, 03/11/2002 - 12:29
Only VoIP, not data (modem or ISDN data) is supported over Q.SIG.
tdn2 Mon, 03/11/2002 - 19:28
Thanks all.
May be this information worthy for adding in Cisco FAQ?
