VPN client 3.1 connecting to PIX 515
Mar 7th, 2002
I have setup the PIX to allow IPSec clients and I am able to connect to the PIX but I cannot access anything on the inside network. My config is:
access-list 101 permit ip 171.16.1.0 255.255.255.0 172.16.2.0 255.255.255.0
ip address outside x.x.x.x 255.255.255.128
ip address inside 172.16.1.254 255.255.255.0
ip local pool vpnclients 172.16.2.100-172.16.2.150
global (outside) 1 x.x.x.x
nat (inside) 0 access-list 101
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
nat (dmz) 1 0.0.0.0 0.0.0.0 0 0
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto dynamic-map dynmap 1 set transform-set myset
crypto map mymap 1 ipsec-isakmp dynamic dynmap
crypto map mymap interface outside
isakmp enable outside
isakmp client configuration address-pool local vpnclients outside
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption des
isakmp policy 1 hash md5
isakmp policy 1 group 2
isakmp policy 1 lifetime 86400
vpngroup vpn3000 address-pool vpnclients
vpngroup vpn3000 split-tunnel 101
vpngroup vpn3000 idle-time 1800
vpngroup vpn3000 password ********
cjacinto Sat, 03/09/2002 - 21:41
  • Cisco Employee,
Check if the inside clients have their default g/w set to the inside of the PIX, or if not set to this and it is set to a router, check if the router has a
def route pointing to the internal ip of the PIX, or at least have a static route to the ip pool you assign to the client, via the pix inside interface.
Possible issue 1, is that you have an network card on the PC that has the same address range as your ip address of the vpn client pool. Do an ipconfig /release all, then reconnect if you have this issue.
Another one, is that your client is behind a device doing PAT/NAT, in its current code, the PIX doesn't support IPSec thru nat, so you have to bypass the NAT
device when you connect to the PIX via VPN.
mjhagen Mon, 03/11/2002 - 11:23
My PC's are set to use a router on the inside as their default gateway. I have static routes on the router to send inside interface traffic (172.16.1.x) to the PIX inside interface (172.16.1.254) and inside interface traffice (172.16.2.x) to the PIX inside interface (172.16.1.254. My VPN client is not behind a NAT/PAT device as I have connected my PC to the outside network of the PIX for testing.
mkalat Fri, 03/22/2002 - 06:30
I think you are missing a static rule.
Something like
static (inside,outside) CallcenterRwell CallcenterRwell netmask 255.255.255.255 0 0
