Warning message
UDP Port 514 active
Mar 8th, 2002
I have a CIDS Model 4230 version 3.0(5)S17. When I run netstat UDP port 514 is active. If I run NRSTOP this port closes and reopens with NRSTART. Does the application need this port open and why?
marcabal Fri, 03/08/2002 - 08:00
  • Cisco Employee,
UPD port 514 is opened by packetd.
Why?
UDP port 514 is the standard syslog port.
You can setup Cisco Routers to forward their syslog messages to the sensor on this port.
Packetd can analyze these syslog messages and fire alarms when specific ACL entries are denying traffic.
Refer to:
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/csids/csids7/unix_cfg/tasks.htm#xtocid2881315
Because the Cisco Router will always send to UDP port 514 we had to make packetd open up this port when ever it starts.
We also had to change the standard syslog utility on the sensor to run on UDP port 515 so it wouldn't interfer with packetd.
