Warning message
IPMap error in HP OpenView
Mar 8th, 2002
I know this is not a Cisco product but it is used in conjunction with CSIDS. I'm hoping someone has gone through this before.
Anyway, I just changed my ip address on my Solaris Director to a private address. When I open Openview to check my alarms, I get an error message:
Fatal IPMap Error: Unable to connect to ovtopmd.
Reason: Cannot connect to ("my old ip address, port=2532): Connection timeout.
Where can I edit this information. I've been looking for hours but could not find it. I appreciate any help, thnx
marcabal Fri, 03/08/2002 - 09:29
  • Cisco Employee,
Here is some information that one of our developers wrote up a few years ago for me. It is out of date since this was back when 5.01 was the latest OpenView version. But it may give you a place to start.
If this doesn't help then I recommend contacting HP directly for their assistance.
There are two things you need to do to change the IP address/hostname
information on a machine running HP OpenView:
1) reconfigure the necessary op-sys IP configuration files
2) reconfigure OpenView to use the new IP/hostname information
To reconfigure OpenView with the new IP/hostname information, you must edit
the following files:
$OV_DB/openview/ovwdb/ovserver
$OV_CONF/ovw.auth
$OV_CONF/ovwdb.auth
$OV_CONF/ovspmd.auth (OpenView 5.0 and higher)
In each of these files, replace the old hostname with the new hostname.
Make absolutely certain that name resolution is working properly in both
the forward and reverse directions (use the "nslookup" command to verify).
Once you have changed the files, bring down all user interface sessions,
then stop the OpenView daemons with "ovstop". Next, run the following
command:
$OV_BIN/xnmsnmpconf -clearCache
Finally, restart the OpenView daemons with "ovstart".
If you don't set up your system correctly, you will get the following
error messages:
ovstart: Can't run on OVW Client
ovw: Cannot open object database: Cannot connect to database
We cannot connect to an ovwdb daemon on the server ,
apparently due to network problems. This could be caused by a problem
with IP routing, a server host that is down, or an unknown server host
name. Contact your administrator for further assistance.
Finally, make sure that you reset your $DISPLAY variable to reflect the
new hostname. If you are using DNS, make sure that the name server
can resolve your name and IP address. If not, when you type "ovw" to bring
up the user interface, the ovw process will start, but Xwindows will not
be able to find the display... Consequently, there will be no windows
displayed on your screen.
ddinh Fri, 03/08/2002 - 12:41
Thanks, it did help. All I had to do was run:
./xnmsnmpconf -clearCache
This cleared out the cache info and it picked up my new configuration from the /etc/hosts file. Good job mate!
