Warning message
PIX 501 Access
Mar 18th, 2002
Hi All,
I have tried to get access to a PIX 501 WAN interface. I want to ssh and use the PDM via the (outside). I can't seem to get it to work. Can some one send me the commands?
I have tried:
ssh 0.0.0.0 0.0.0.0 outside
and it does not work.
Jerry Roy
mholmsen Fri, 03/22/2002 - 22:13
To make ssh work you also have to generate rsa keys with the ca generate rsa jeys 512.
I have just put up an solution like the one you are telling about, and I put up an vpn for the ssl connection to the pdm, and if the tunnel went down I made sure that I could reach it by ssh.
