Warning message
Trace command will reboot the router
Mar 19th, 2002
Does anyone know or experience this kind of problem
that we encountered? In the CLI, if we trace
"times.com" our router starts to reboot itself and
if other sites the results are normal. What do you
think? It could be the IOS?
Details:
Router#s ver
IOS (tm) RSP Software (RSP-PV-M), Version 12.1(8), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2001 by cisco Systems, Inc.
TIA
Van
wzhang Fri, 03/22/2002 - 11:15
  • Cisco Employee,
This most likely is an IOS bug. You may want
to open up a TAC case and they should be able
to help you decode the stack trace and tell you
if this is a known problem or open up a new
bug for you.
