Translation Pattern
Mar 20th, 2002
I finally downloaded 12.2XN and made my Vg200 work with mgcp using 1 E1 pri with 30 channels with 100 dns assigned from my PTT.
the number is 8112000 up to 8112099.
My question is :
If I assign 4 digit DNs from 2000 to 2099 what translation pattern should I use to make incoming calls ring to the appropriate phone? (PTT's DID works for the last 3 digits)
Or else if I use 3 digit DNs from 100 to 199?
Thanks in advance
cparvex Wed, 03/20/2002 - 05:05
Hi, maybe try to use tech-prefix command
on the gateway, give me your feedback if it works.
Bye
mharitos Thu, 03/21/2002 - 00:44
As far as I know tech-prefix works only with voip dial peers. Since I'm using mgcp all call handling is processed only through ccm.
