Warning message
what to use instead of Static
I am doing a gateway project which includes PIX I need to configure it in accordance with the Evaluated Configuration, I am using 5.2(3) I have included a sample of the config but am having trouble with meeting all the requirements I hope you can help.
The Evaluated Config Document says not to use static because it activates NAT but how else will I open an inbound connection to the Inside hosts?
any help would be terrific
nameif ethernet0 outside security0
nameif ethernet1 inside security100
hostname client-PIX
names
name 10.9.10.11 MailRobot
name 10.9.10.9 clientFW1
name 10.9.11.1 GatewayManager
name 192.168.208.35 CA-Dev
name 10.9.11.3 client-App
name 192.168.208.68 CA-Prod
name 10.9.11.2 client-RA
name 10.9.10.0 DMZ
name 10.9.11.0 Protected
access-list inside_access permit tcp host client-RA eq 830 host CA-Dev eq 830
access-list inside_access permit tcp host client-RA eq 830 host CA-Prod eq 830
access-list inside_access permit tcp host client-App eq 1098 host MailRobot eq 1098
access-list inside_access permit tcp host client-RA eq 7676 host MailRobot eq 7676
access-list inside_access permit tcp host client-App eq 7676 host MailRobot eq 7676
access-list inside_access permit tcp Protected 255.255.255.0 eq www DMZ 255.255.255.0 eq www
access-list inside_access permit tcp host GatewayManager eq 1253 DMZ 255.255.255.0 eq 1253
access-list inside_access permit tcp host client-RA eq 1098 host MailRobot eq 1098
access-list inside_access permit udp Protected 255.255.255.0 eq domain any eq domain
access-list outside_access permit tcp host CA-Dev eq 829 host client-RA eq 829
access-list outside_access permit tcp host CA-Prod eq 829 host client-RA eq 829
access-list outside_access permit tcp host MailRobot eq 1098 host client-RA eq 1098
access-list outside_access permit tcp host MailRobot eq 1098 host client-App eq 1098
access-list outside_access permit tcp host MailRobot eq 7676 host client-RA eq 7676
access-list outside_access permit tcp host MailRobot eq 7676 host client-App eq 7676
access-list outside_access permit tcp DMZ 255.255.255.0 eq www Protected 255.255.255.0 eq www
access-list outside_access permit udp any eq domain Protected 255.255.255.0 eq domain
pager lines 24
interface ethernet0 auto
interface ethernet1 auto
mtu outside 1500
mtu inside 1500
ip address outside 10.9.10.254 255.255.255.0
ip address inside 10.9.11.254 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
arp timeout 14400
logging timestamp
logging host 10.9.11.1 tcp/1470
nat (inside) 0 0.0.0.0 0.0.0.0 0 0
static (inside,outside) client-RA client-RA netmask 255.255.255.255 0 0
static (inside,outside) client-App client-App netmask 255.255.255.255 0 0
static (inside,outside) GatewayManager GatewayManager netmask 255.255.255.255 0 0
access-group outside_access in interface outside
access-group inside_access in interface inside
route outside 0.0.0.0 0.0.0.0 clientFW1 1
David White Mon, 04/01/2002 - 08:53
  • Cisco Employee,
You can use the command "nat (inside) 0 access-list "
Example:
access-list nonat permit ip host servA host servA
access-list nonat permit ip host servB host servB
nat (inside) 0 access-list nonat
Now, servA and servB will not have their address translated, but users on the Outside can still access them (assuming you are permitting access in with access-list outside_access)
Sincerely,
David.
