router reboot bus error
awafe
cisco router reebboot by itself has error message
System restarted by bus error at PC 0x604DDAFC, address 0xD0D0D0D
System image file is "slot0:rsp-jsv-mz.113-6.T", booted via slot0
IOS version 11.3(6)T
It seems to be has IOS bug any suggestion
scarothe
Greetings:
How long have you had this router. Code is rather elderly and it would seem odd that if it has been up for quite a while that all of a sudden, a bug would kick in.
How many times has it rebooted? Have you made any changes to the configuration lately or changed IOS?
Thanks...Steve
No their is no chnaging it happen twice in two week only thing I found IOS has been upgrade in 1998 11.3(6)T
sh ver
sco RSP4 (R5000) processor with 65536K/2072K bytes of memory.
R5000 processor, Implementation 35, Revision 2.1 (512KB Level 2 Cache)
Last reset from power-on
G.703/E1 software, Version 1.0.
X.25 software, Version 3.0.0.
SuperLAT software copyright 1990 by Meridian Technology Corp).
Bridging software.
TN3270 Emulation software.
Chassis Interface.
1 AIP controller (1 ATM).
3 VIP2 controllers (5 FastEthernet)(8 Token Ring).
5 FastEthernet/IEEE 802.3 interface(s)
8 Token Ring/IEEE 80q
2.5 interface(s)
1 ATM network interface(s)
123K bytes of non-volatile configuration memory.
20480K bytes of Flash PCMCIA card at slot 0 (Sector size 128K).
8192K bytes of Flash internal SIMM (Sector size 256K).
No slave installed in slot 3.
Configuration register is 0x102
