Warning message
1720 reload repeatly
Apr 4th, 2002
I have a 1720 router connected to ISP with leased line for nearly two years. It worked fine before last month the leased line speed upgraded to 256Kbps. After the upgradtion, it often automatically reload. I check the memory, it has 16M bytes DRAM. Why did this problem happen? Anybody's advice is appreciated.
Thanks in advance.
ruwhite Mon, 04/08/2002 - 04:25
  • Gold, 750 points or more
Check a show version, and see why it's reloading. Also make certain you have console logging on, and check it every now and then to see what's in there. If you can catch it just before the reload occurs, the console log might tell you a great deal.
Russ
