Warning message
bulk delete subscribers
Apr 5th, 2002
  • Bronze, 100 points or more
Is there a way to delete subscribers in bulk from SA? Or do I need to delete them from Exchange using some sort of bulk editing utility. (Any caveats when doing that?)<br><br>The unity bulk edit utility seems to be just that - a utility to edit but not delete subscribers/call handlers.<br><br>
Anonymous (not verified) Fri, 04/05/2002 - 10:10
There is a bulk Subscriber delete tool for Unity 3.x versions out on AnswerMonkey but I don't have one tooled to handle the older Unity 2.x DOH interface.
the best I can suggest is to delete the users in Exchange in bulk and then run the dbWalker utility with the "remove orphaned call handlers" option checked... this will run through an rip out all the call handlers and associated Unity data from those old accounts that are now removed.
If you want to keep the mail users and just remove the subscriber information off of them, there isn't a good way to do that in bulk in 2.x at the moment.
Jeff Lindborg
Unity Technical Lead/Answer Monkey
Cisco Systems
[email protected]
http://www.AnswerMonkey.net (new page for Unity support tools and scripts)
