Warning message
Best way to connect two 2610's? Via PVC
scarothe Mon, 04/08/2002 - 09:28
Greetings:
Doesn't matter whether you do that or IP unnumbered. Will function the same.
Thanks...Steve
Thats cool.
I want to set both offices up as if they are in the same location. I want both to pick up IP's from the DHCP in building 1 etc. Basically the routers are in place but I want them to be invisible, so the users in building have exactly the same resources etc as the users in building one...
any ideas?
TIA
nuno.morais Tue, 04/09/2002 - 02:33
Hi.
If you want both offices to share the same subnet, you may want to use some form of bridging... You may also need DLSW+ between the routers.
Hope this helps.
NM
tmoreo Sat, 04/13/2002 - 09:40
If all you want is for a central site to give DHCP to a remote site for centralized administration try using the "IP helper" command.
