Warning message
gary.shaw Tue, 04/09/2002 - 00:08
Have you got the latest code? Ive not heard of that one before.
If your on the latest code it could be a hardware fault, I'd log a TAC, you need to get some logs from the box when it fails really.
cgelnett Tue, 04/09/2002 - 09:01
I have the same versions, 1.1(1) with CM 3.1.
I think we may have found the problem. We have two VG248 and when the customer rebooted both VG248 at the same time I found a duplicate IP address error in the log. The other device was the other VG248. So I placed a fixed IP address on each of the box and we are waiting to see if the problem happens again.
