mtu=300 for Vo/IP QOS, but Internet slow from branch office.
Apr 8th, 2002
From recommendations for Vo/IP QOS, the mtu=300 was used on a 3640 router serial interface at HQ, and also at the branch office 1751v router. HQ provides Internet access for the branch office, the branch office has a frame-relay conenction back to HQ. Both routers have a Vo/IP/Frame configuration, and voice calls are working fine. However, now when the branch office tries to access some web servers on the Internet, it is very slow, and some sites timeout when being connected to. We are seeing the "need to fragment (mtu 300)" message at the 3640 router (verified through TCPCUMP utility on the customer's Check Point firewall.)
So, we are thinking that the small MTU is not compatible with the ISP's access router (a 2600 at HQ.)
Is it possible to set the router configs so that the MTU=300 is only used for Vo/IP packets?
Alternatively, couldn't we just remove the MTU=300, so that there is a larger window? If so, will the Vo/IP QOS suffer much?
For brevity, here is part of the 3640 config:
voice rtp send-recv
interface Serial0/0
description frame-relay for HQ to: San Fran.,CA;
mtu 300
bandwidth 768
no ip address
encapsulation frame-relay
service-module t1 timeslots 1-12
frame-relay traffic-shaping
frame-relay lmi-type cisco
frame-relay ip rtp header-compression
interface Serial0/0.1 point-to-point
description PVC to San Fran; DLCI=120
ip address 10.1.252.1 255.255.255.252
frame-relay interface-dlci 120
class VoIPovFr192
map-class frame-relay VoIPovFr192
no frame-relay adaptive-shaping
frame-relay cir 192000
frame-relay bc 1920
frame-relay fair-queue
frame-relay fragment 240
frame-relay ip rtp priority 16384 16383 48
dial-peer voice 4010 voip
destination-pattern 2100
session target ipv4:10.1.252.2
dtmf-relay h245-alphanumeric
ip qos dscp cs5 media
and, here is part of the 1751v config:
voice rtp send-recv
interface Serial0/0
description frame-relay for San Fran, CA to HQ
mtu 300
bandwidth 384
no ip address
service-module t1 timeslots 1-6
description PVC to HQ
ip address 10.1.252.2 255.255.255.252
frame-relay interface-dlci 100
class VoIPovFr192
frame-relay bc 1920
dial-peer voice 2100 voip
destination-pattern 4010
session target ipv4:10.1.252.1
asparrowhawk Wed, 04/10/2002 - 09:33
The idea is to stop large data frames getting in the way of voice frames and causing variable delays between voice frames (jitter). The "frame-relay fragment 240" statement in your frame relay map class acheives this, so restricting the MTU is redundant - large frames may be getting chopped to 300 bytes because of the MTU, then each fragment further chopped to 240 and 60 bytes at the DLCI. Try opening out the MTU to standard and retesting, there will be some degradation in performance caused by fragmentation but it shouldn't be too severe.
bharath.mallik@... Wed, 04/17/2002 - 20:39
hi
Make this MTU has 1500 then check the speed of internet as well as voice quality it will be fine.
pacameron Wed, 05/01/2002 - 18:02
  • Silver, 250 points or more
Get rid of the MTU setting on the main serial interface - you have already configured FRF12 under the subinterface. The FRF12 will transparently fragment the traffic at layer 2 - you don't need both.
Many upper layer protocol servers such as HTTP and FTP will often set the DF (Don't Fragment) bit of the IP header to make transfers as efficient as possible, so if the packet gets to a interface where the MTU has been reduced it will often be dropped, hence the application either stops or slows right down.
f.huynh Thu, 06/20/2002 - 19:48
I have an E1 link that run on frame-relay, with 2 heavy data pvc and 1 voice pvc. I also implemented pvc priority with queue depth (high, med, normal, low) 10 30 100 200. Voice pvc is set to high, while the 2 data pvc is set to med and low. Is this the probably way to do qos for this scenario. FRF12 is also configured base on the lowest cir, 128k.
