Lightning Fax
Apr 11th, 2002
  • Bronze, 100 points or more
Can someone help me with this issue? The LFExGateway service on our Unity server keeps getting the Dr.Watson sharing violation error when it try to start. Any input is appreciated.<br><br>Dave<br><br>
Anonymous (not verified) Thu, 04/11/2002 - 10:29
Having the fax gateway service (Lightning Fax or otherwise) installed on the Unity server is not supported. The last version having LF installed on box was supported was 2.4.6. You'll need to get that fax server installed off box.
Problems with the LF gateway are tricky, you wont find folks out here that know much about the ins and outs of what that guy is trying to do at startup. You'll have better luck contacting Interstar directly.
Jeff Lindborg
Unity Technical Lead/Answer Monkey
Cisco Systems
[email protected]
http://www.AnswerMonkey.net (new page for Unity support tools and scripts)
