Warning message
MWI/Port conifg/VMO
Apr 11th, 2002
  • Bronze, 100 points or more
I have a few issues that i thought someone can help me with. Unity 3.1(1) with cal man 3.1 with unified messaging. I just finished install but the MWI is not working for all phones. Also although we have multiple ports it seems that we get a busy signal if one user is accessing voicemail . Also view mail for outlook installed fine on my 2000 pro machine however install fails on xp pro. Thank you for any help you can provide.<br><br>
Anonymous (not verified) Thu, 04/11/2002 - 00:18
I found in the documentation that if the user has an outlook rule to moe mail to another folder than voicemail from that ohter user will not light the MWI. still having the busy port problem. any suggestions?
