Fallback Password problems (3550 &2950)
Apr 12th, 2002
I realy belive I've missed something. When the 3500 &2950 switches loose conection to the tacacs+server I cannot get access. The switch is'nt giving me the option to use the fallback. The following is a selection og the configs.
logging buffered 10000 debugging
no logging console
aaa new-model
aaa authentication login default group tacacs+
aaa authentication login no_tacacs enable
aaa authentication ppp default group tacacs+
aaa authorization exec default group tacacs+
aaa authorization network default group tacacs+
aaa accounting exec default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
and at the vty line -
line vty 0 4
password whatever
line vty 5 15
password whatever1
What am I missing ? Thanks
Erick Bergquist Sun, 04/14/2002 - 19:21
  • Silver, 250 points or more
You need to add a 'local' to end of aaa commands. You'll also need a username configured for each user.
username x password y
aaa new-model
aaa authentication login default group tacacs+ local
OR you can make the vty lines authenticate locally only:
aaa new-model
aaa authentication login NO_AUTH none
line vty 0 4
login authentication NO_AUTH
